HOME
ASK A QUESTION
REPAIR GUIDES
BECOME A MEMBER
LOG IN
Login with Facebook
OR
Remember me
NOT A MEMBER?
FORGOT PASSWORD?
CONTACT US
PRIVACY POLICY
TERMS AND CONDITIONS
Home
Ford
F-150
Drivetrain
Transmission
Clutch
Replace/Remove
SPONSORED LINKS
1992 Ford F-150 CLUTCH
RSHAK
MEMBER
1992 FORD F-150
Transmission problem
1992 Ford F150 6 cyl Two Wheel Drive Manual
hOW DO I CHANGE OUT MY SW-5993
Saturday, August 28th, 2010 AT 3:09 PM
DOCFIXIT
MECHANIC
What's a SW-5993?
SPONSORED LINKS
Saturday, August 28th, 2010 AT 3:31 PM
RSHAK
MEMBER
1 POST
Clutch pedal position sensor.
Saturday, August 28th, 2010 AT 3:52 PM
DOCFIXIT
MECHANIC
Guessing you mean clutch interlock switch pull of retaining clip remove see diagram
Sunday, August 29th, 2010 AT 12:37 PM
Please
login
or
register
to post a reply.
Related Transmission Clutch Replace/Remove Content
2000 Ford F150 Clutch
Very Soon After Have My Clutch Replaced My Truck Started To Shake Really Badly When I Take, More Often When The Truck Is Warm. The Clutch...
Asked by
Blairsteven
2000
FORD F-150
Clutch Becomes Soft Only While Engine Running
My Truck Has A Zf5 Manual In It. Recently I Did The Rear Main Seal And After I Installed My Transmission And Bleed The Clutch Everything...
Asked by
Michael Gravalec
1 ANSWER
1 IMAGE
1990
FORD F-150
1996 Ford F150 Clutch Problem
About Six Months Ago I Had The Clutch Replaced In My Truck. I Noticed This Problem Then, But When I Took It Back To The Repair Shop I Was...
Asked by
nynnianne
1996
FORD F-150
1996 Ford F150 How To Replace Clutch
First, How Do You When Your Clutch Is Going Bad/out. Second - How Do You Replace Clutch
Asked by
fuzzyfubu00
1 ANSWER
1996
FORD F-150
Clutch Replace
I Have A 2001 Ford F150 That Needs The Clutch Replaced. When I Called The Auto Parts Store, They Ask If It Was Self Adjusting Or Non Self...
Asked by
thedeems98
1 ANSWER
2001
FORD F-150
VIEW MORE
SPONSORED LINKS
Clutch Not Working
Throwout Bearing - Secondary Cylinder Replacement
Pilot Bearing Replacement
Online car repair manuals
