1996 Ford F-150 clutch problem
NYNNIANNE
  • 1996 FORD F-150
About six months ago I had the clutch replaced in my truck. I noticed this problem then, but when I took it back to the repair shop I was told they didn't notice what I was saying. Then three weeks ago it went out again. Now, as before. It stutters as I take off either in first or reverse. Sort of a jumpy take off. It didn't do this before the clutch went out the first time. I've never driven a hydrolic clutch before, but I can't even fathom that that has anything to do with it unless it's a problem with the hydrolic system it'self. Not my driving. I've been driving standard transmissions for over 30 years and never had this problem before. Any ideas what could be the problem since the auto shop doesn't seem to want to look for the problem.
thanks
Nynn
Monday, January 2nd, 2006 AT 1:27 AM
PALCO
  • 83 POSTS
One or more torque springs have broken and/or colapsed
Monday, January 2nd, 2006 AT 3:52 AM
BRETT ANDERSON
  • 6 POSTS
Make sure they turned the flywheel
Tuesday, January 3rd, 2006 AT 9:13 AM
DARRYL
  • 61 POSTS
Hello: If it is a hydraulic clutch then it isn't a linkage problem, thats for sure. Wonder if they put the clutch disk in backwards. In most cases this is not possible, but if it can be put in backwards then the hub of the clutch that has the springs will not work and act like a springless center hub. Possibly grease on the surfaces, sometimes that makes them shudder. I don't know what else it might be without a little more info.
Good luck
Darryl.
Monday, January 16th, 2006 AT 9:12 PM
DB554
  • 35 POSTS
It could be as simple as a piolot bearing a lot of times they are overlooked
Tuesday, January 17th, 2006 AT 3:56 PM
