2000 Ford F150 bad idle
158,000 MILES • 6 CYL • 2WD • AUTOMATIC
OTISA2007
my truck is giving 2 codes left and right bank lean it seems to run ok going down the road but at idle it will run smooth for a few minutes then try to die it will smooth out then after a few minutes it will di it again sometimes it will die but always cranks right back up i have had it to the dealer twice and they cant seem to figure it oout
Aug 30, 2010 at 5:36 PM
  • 75,988 POSTS
Try cleaning out the idle air control valve and also check and test below
Lean fuel condition could be caused by one of the following below:
1.Vacuum leaks
2.EGR and PCV valve.
3.Low fuel pressure.
4.Dirty fuel injectors.
5.Mass Air Flow Sensor.
6.Oxygen Sensor.
Aug 30, 2010 at 6:51 PM
