2000 Ford F150 Idle
2000 FORD F-150
BOZ3049
Engine Mechanical problem
2000 Ford F150 V8 Two Wheel Drive Automatic
My F 150 4.6 V-8 will occasionally not idle when starting cold. I noticed this more when it was left in the rain. I saw a service bulletin where the windshield was not seated in those years, causing electrical problems on the firewall. I got a new windshield and it is happening still. Also when I turn the key, all guages spin to the max, then return to normal.
Nov 18, 2009 at 9:54 PM
  • 110,244 POSTS
Has the check engine light ever come on?
Nov 18, 2009 at 10:40 PM
BOZ3049
No, never came on. My friend has a 2000 Expedition, 4.6, the windshield change stopped all his problems.
Nov 18, 2009 at 10:57 PM
  • 110,244 POSTS
They did have a problem with the window leaking down on to the fuse box below the windshield. The "GEM" which is a generic electronic module is mounted on the rear of the fuse box. What would happen is water would get to it and cause problems. CHeck that. It is a thin black plastic module. See if there is any evidence of water getting to it. Let me know what you find.
Nov 18, 2009 at 11:15 PM
