Electrical problem
2000 Ford F150 6 cyl Two Wheel Drive Automatic 160 00 miles
I need a detailed description of how to replace alternator or even better video or hint where can I found that infor. Thanks!
Saturday, September 12th, 2009 AT 7:25 AM
MECHANIC
I have no video, but here is the general info:
Disconnect the battery, remove serp belt, remove wires from the rear of the alt, and unbolt it from the mounting brackets. Reverse the order to replace it.
