1989 Ford F150 alternator
LORRICK
Electrical problem
1989 Ford F150 6 cyl Two Wheel Drive Manual
i need instructions (and photos if available) on how to remove and install a new alternator. please
Mar 14, 2009 at 3:30 AM
RACEFAN966
  • 5,029 POSTS
Ok it isn't that hard. You will need to remove the belt first then disconnect the poss battery term. Then unplug the two plugs to the alternator and then unbolt the two bolts then replace it in reverse order thats it. If you need anymore help get back to me.
Mar 15, 2009 at 3:14 AM
