Alternator Replacement
130,300 MILES • 5.4L • V8 • 4WD • AUTOMATIC
JFPAY01
The test I have performed indicates that I have a bad rectifier pack in my alternator. This is a non-serviceable unit. Looking at Fordparts.com website it suggest replacing the unit with a 115 amp alternator, fine. But, it also says that this unit is the same as a 130 Amp alternator.
My question is: If I replace the original unit with a 130 amp alternator would I comply with the wiring gauge rating of my truck?
Dec 8, 2016 at 1:33 AM
HMAC300
  • 48,601 POSTS
there should not be a problem with that.
Dec 8, 2016 at 4:19 AM
