Idle surges
LEGITIMATE007
  • 5,121 POSTS
Very good, that is mostlikely the problem, is there a check engine light on?
Monday, June 8th, 2020 AT 5:11 PM (Merged)
VANGREENE
I took a meter and ohmed out the TPS and it checked okay. The resistance increased as the throttle was opened from.3 to 3. I cleaned the connectors and started the truck. It was idling okay for a few minutes but it then went to idling about 3000 RPM again. I ohmed out the TPS again and it was very high. It appeared to be affected by heat when the truck was running. I replaced the TPS again and it seems to be working fine. I disconnected the battery to reset the computer and cranked it up then checked for codes again. I got a 1 1 1 which I believe means it know passes the test. Just for curiosityI ohmed out the TPS again and the resistance reduced as I opened the throttle. I drove it for about 25 miles and it seems to be working okay for know and I hope it's fixed. Thanks for the help and great communication.
CTHENKE1999
No the check engine light is not on
LEGITIMATE007
  • 5,121 POSTS
Before doing the upper plenum, check the engine coolant temp sensor, and throttle position sensor
CTHENKE1999
Ran test on a snapon scanner all sensors test good. Also checked for other vaccum leaks I singled out each and every vaccum line one at a time.
