1999 Ford F-150 fuel pump
USMCRETIRED50
  • 1999 FORD F-150
  • V8
  • 98,000 MILES
I turn the power on and I went to the fuel pump, to check the power and found no power to the wires. The fuse is good and the relay is good too. And check the safey switch to and is good too.
Sunday, July 25th, 2010 AT 10:50 PM
  • 110,052 POSTS
Did you have a helper turn the key while you checked?
Sunday, July 25th, 2010 AT 11:45 PM
USMCRETIRED50
Yes I did
Monday, July 26th, 2010 AT 7:21 PM
USMCRETIRED50
I turn on the key and I check the power on the fuel shut-off switch. And I found no power to the switch
Monday, July 26th, 2010 AT 10:34 PM
  • 110,052 POSTS
Check the EEC relay in the power distribution box under the hood. Switch it out with another relay with the same part number to see if that changes anything.
Tuesday, July 27th, 2010 AT 12:34 AM
USMCRETIRED50
Sorry still not working
Wednesday, July 28th, 2010 AT 6:50 PM
  • 110,052 POSTS
You are going to have to trace the wiring to determine where the power is lost. If you have it at the relay, the EEC is good, and not at the fuel shut down, the only thing I can think of is a bad ASD or broken wire.
Thursday, July 29th, 2010 AT 12:03 AM
