1999 Ford F150 Engine wont run
91,000 MILES • V8 • 4WD • AUTOMATIC
OZZY0256
My f-150 has been having problems lately. When i start the engine it will turn over and start but then immediately dies. if i start it and give it gas it will keep running as long as i am revving it but it still runs bad and when i let off the gas it will die. i just replaced the fuel filter. what do you think the problem might be? thank you for any help.
Nov 22, 2009 at 11:03 AM
BMRFIXIT
  • 19,053 POSTS
Check engine light on ?
need to check for code s
check for vacuum leaks under the hood
check IAC remove and clean
Nov 22, 2009 at 11:15 AM
OZZY0256
[quote:34f9716cce="BMRFIXIT"]Check engine light on ?
check IAC remove and clean[/quote:34f9716cce]
No the check engine light is not on. What is the IAC
Nov 22, 2009 at 11:56 AM
BMRFIXIT
  • 19,053 POSTS
Idle Air Control Valve on the throttle body
Nov 23, 2009 at 11:47 AM
