1998 Ford F-150 Truck dies with no electrical
WILLIE22
  • 1998 FORD F-150
  • V8
  • 4WD
  • 150,000 MILES
My truck runs and starts but goes electrically dead after running for 5-10 min, no gauges, no horn, no windows, no locks, no flashers, no radio nothing electrical, but continues to run for another 5-10 min then dies completly. If I let it set for an hour or so then it restarts with full power.
Tuesday, May 18th, 2010 AT 7:54 PM
BMRFIXIT
  • 19,053 POSTS
Start your check with the battery terminals
clean and tighten
start engine and check charging system and alternator
volts should be at about 14V with engine running
Tuesday, May 18th, 2010 AT 8:02 PM
WILLIE22
Thank you, I did check the battery terminals and cables. They are tight and clean.
There was aslo a beeping when the electrical went. Four, above normal volume, beeps repeated three or four times after I lost the dash board and electrical. My wife said it did the same thing to her as she pulled into the parking at school.
Wednesday, May 19th, 2010 AT 6:03 AM
BMRFIXIT
  • 19,053 POSTS
After it dies check for power at fuses
check for volts between alternator big wire and engine ground
if ok suspect and check ignition switch
Wednesday, May 19th, 2010 AT 6:07 AM
