Passenger compartment fuse box replacement
100,000 MILES • 3.5L • 6 CYL • 4WD • AUTOMATIC
CNLOOPER
  • 11 POSTS
Fuse box is burnt up! What precautions should I take and how would you recommend doing it and would I have to reprogram it
Mar 22, 2016 at 6:32 AM
  • 31,937 POSTS
how bad is the loom behind the fuse bot, are the wires damaged? do you know what caused the problem in the first place?
Mar 22, 2016 at 6:36 AM
CNLOOPER
  • 11 POSTS
No wires nothing burnt up sorry didn't mean to put that the problem I'm having is the big plug on top I have to mash and hold it in for truck to work and then runs fine but for some reason it's not getting good connection for some reason
Mar 22, 2016 at 6:46 AM
CNLOOPER
  • 11 POSTS
I have to put pressure on it and hold it in while someone cracked it I did disconnect it to see if and terminals where lose first I disconnected negative battery cable
Mar 22, 2016 at 6:49 AM
