Here is a good definition that I was able to find.
The Idle Air Control (IAC) valve adjusts the engine idle speed. The valve is located on the side of the throttle body. The valve is controlled by a duty cycle signal from the PCM and allows air to bypass the throttle plate in order to maintain the proper idle speed.
SPONSORED LINKS
Wednesday, September 1st, 2010 AT 6:58 AM
