Wednesday, November 11th, 2009 AT 4:00 PM
My truck recently started to make a soft but high pitch reving sound when I initially start driving and accelerating. The sound is as it shifts automatically into each speed/gear until it hits about 35mph. I just had my transmission checked and flushed, etc, and everything else looks okay. Today my truck would not completely start up unless I hit the gas when turning key over. That only happened once and then it would start just fine. Per the mechanic, it could be the Idle Air Control or the corrosion on my battery that is making the starting up difficult. But, my battery being clean would not effect a high-pitched reving sound when starting to accelerate. The rest of the truck runs smoothly and no problems on the road. What do you think?
