Hay, thanks for the positive feedback and I'm glad you got it fixed. If it happens again in the future, there is a vacuum hose on the rear of the intake that is molded into a 90 degree bend. They like to dry rot there and leak.
Good luck and learn as much as you can about everything. I remember when 15.00 dollars an hour for a mechanic was high. Now, many of them are getting over 100.00. Keep your money in your pocket if you can. Don't give it away.
SPONSORED LINKS
Thursday, May 20th, 2010 AT 10:45 PM
