Check engine light?
  • 31,937 POSTS
Hi there,
check for any exhaust leak up stream of the O2 sensor, check for any vacuum leaks check the continuity of the o2 wiring from the sensor to the ECU, start here.
Mark (mhpautos)
Wednesday, September 9th, 2020 AT 6:32 PM (Merged)
MJR346
  • 132 POSTS
Bank 1 sensor 2 is the right rear o2 sensor behind the cat on passenger side. Without code, hard to diagnose, but either sensor is not outputting, wires are open, burned on exhaust, or cat has internal issue with it (usually bad o2s and internal issues lead to a p0420)
WMBRGI
  • 1998 FORD F-150
  • V8
  • 4WD
  • 180,000 MILES
The check engine light was flashing with the switch on, not running, turned key off and back on light was steady, and would crank. Now check engine light does not come on. I have checked all fuses, all good, unless there is a hidden one. I can't pull codes because of no check engine light.
Wednesday, September 9th, 2020 AT 6:33 PM (Merged)
Hi wmbrgi, Welcome to 2carpros and TY for the donation
On many cars, the ECM (that's the electronic brain) is on the same fuse circuit as other electrics like the cigarette lighter/accessory port. The lighter is prone to blow fuses on some vehicles, and if there's no juice going to the ECM, it can't tell you what's wrong.
Check and test fuse no.24 30amp and fuse no.1 5amp in the PDC this is the one that powers the PCM see below
https://www.2carpros.com/forum/automotive_pictures/12900_PCM_4.jpg
SLICK
  • 1998 FORD F-150
  • 4WD
  • 210,000 MILES
When I turn the key on my check engine light does not come on. What could be the problem? I have a 98 f150 4x4, 5.4L
CJ MEDEVAC
  • 11,004 POSTS
That's the reason for the lights to appear when you do that---to verify the light works! More than likely, you need to replace the bulb, just in case it does need to alert you there is a problem.I have seen people remove the bulbs, before they sold their cars, cause they could not/ would not, do the proper repairs, so it would stay off.---The Medic
DWIGHT1969
  • 1998 FORD F-150
  • 6 CYL
  • MANUAL
  • 108,250 MILES
I have a 1998 F-150 w/4.2L.I have the trouble codes 1537-1538 and 0171 - 0174. What is the Intake Manifold Runner Control. And how is it fixed?
MJR346
  • 132 POSTS
You have a air leak somewhere causing the 171-174 normally it's the PCV valve tube I see that breaks on these.
The Intake Manifold Runner controls are on the back of the motor and require removal of the upper part of the intake manifold (it seperates into two) to access. Usually the bushings that hold the actuator rods break and cause the codes
MASELLS
  • 1998 FORD F-150
  • 6 CYL
  • MANUAL
  • 105,000 MILES
How do I turn off the engine light I have checked everything out cant get the light off is their a switch?
BLUELIGHTNIN6
  • 16,542 POSTS
You need to retrieve the codes that the computer has stored. Have vehicle scanned with diagnostic scanner. Once codes are retrieved the diagnostic scanner can delete the codes off of the computer which will turn off the engine light.
Thanks for using 2CarPros. Com!
MIKEGROSS12
  • 11 POSTS
  • 1998 FORD F-150
Engine Mechanical problem
1998 Ford F150 6 cyl Four Wheel Drive Manual
scan tool brought up code p1538. Possible stuck lifter.(No noises). Tried lucas in the tank & tried stp in the throttllebody. Light still on. Cant find vacuum leak anywhere. Unsure about location of imrc solenoid & the irmc motors. Truck runs excellent needs inspection wont pass with light on. Dont wont to mess anything up worse if there is a problem
2CARPRO JACK
  • 11,533 POSTS
Mitchell doesnt show a code P1538 for a 98 F-150. All of the codes for that area of #s refer to the IMRC, which is mounted on the lower intake and controls the extra runner flaps in the manifold. Look for broken connectors for the rods that go from teh motor to the intake levers. If all are ok, then it could be the IMRC motor, have seen them go bad as well. The light will probably need to be cleared with a scan tool
