My check engine light has been on in the truck for quit some time. The mechanic I go to has run tests on it and the codes it throws back are Bay 1 & 2 are low. I am not sure what that means and he was not certain either. Just recently the truck has started to have the check engine light flash. I am not sure what the cause of the flashing light is, but it only does it on occasion. It does not happen everyday, just once in a while. Once it flashes for a few seconds it then goes back to just staying on.
The other question I have is my truck has just started this idolling problem when the cold weather decided to set in. It wont stay running when in idol, and it will die. I am not sure the cause of this. If it is warm outside it does not have this problem. I ran a couple tanks of STP gas treatment through the truck and it seemed to help it and it hasn't gave me any problems lately, but was curious what it could be causing this problem.
Wednesday, September 9th, 2020 AT 6:32 PM
(Merged)
