1998 Ford F150 Battery dies
102,000 MILES • 6 CYL • 2WD • AUTOMATIC
DALE FRANKLIN
My battery continues to die after replacing it. The alternator charges enough that when I drive ,even after jumping starting the truck, the battery becomes fully charged. After a couple of days, the battery is drained dead. Today, when I turned the truck off, I heard a clicking coming from under the middle of the dash. It sounded like relays. The noise came from a box about 3"X2" next to the two testing plugs. I have put in a GEM module the other day, but that was because the wipers stopped working. I had starting problems before that. Until I heard the clicking noise, I thought that I might have a bad diode in the alternator. Thanks for any help.
Jan 7, 2008 at 12:42 PM
BDWS6
hi. it sounds like I,m having the same problem with my f150. I think my ingition switch might be bad. could you let me know if you find out somthing else. thanks
Jan 11, 2008 at 7:41 PM
DALE FRANKLIN
Sure I'll let you know.
Jan 14, 2008 at 4:21 AM
