2002 Ford F-150 truck jumps/vibrates coming out of 1st and
2002 FORD F-150
211,000 MILES • 6 CYL • 2WD • MANUAL
21RJR12
when i release the clutch from a dead stop in 1st or reverse it jumps/shudders hard. when I give more gas at higher rpms its smoother. I had my clutch and slave cylinder replaced not to long ago.
Oct 10, 2010 at 9:09 AM
  • 110,240 POSTS
What you are describing is chattering. It can be caused by a worn clutch plate, weak pressure plate, or the clutch disc is contaminated by oil, coolant...
Did the problem just start since the slave was replaced?
Oct 10, 2010 at 2:56 PM
21RJR12
thanks for the quick response. the answer to your question is yes. Just shortly after the clutch/slave was replaced it began. Once the truck is moving all other gears 2-5 work fine. this problem has been going on a while, ive just learned to deal w/it. my old mechanic who replaced my clutch/slave said it was a sensor/intake problem and could run 250-650 to fix. not sure what to believe.
Oct 12, 2010 at 10:26 AM
  • 110,240 POSTS
There is nothing on the intake or a sensor for the clutch. Honestly, either the slave needs rebled or the pressure plate is getting weak.
Oct 13, 2010 at 3:50 AM
