2001 Ford F150 Truck has to be jump started
149,000 MILES • 6 CYL • FWD • AUTOMATIC
DJATCORNER2
I recently cleaned my battery terminals using NAPA battery terminal cleaner. I now have to jump start my truck every time I attempt to start it. My battery has a full charge, my stereo, lights, alarm, etc. all work and my alternator was replaced within the year. Once the truck is started all is well but there is an burnt egg smell inside. The starter is a little sluggish and clicks when I attempt to start without a jump. Is my starter bad or did I short something like a battery cable?
Dec 3, 2008 at 7:02 AM
  • 75,988 POSTS
Get the battery load tested-make sure its cleaned and properly tightened then come back-The battery could be sulfated unable to take the charge-Also might consider loading the alternator too -to check if its putting out the correct output.
Dec 3, 2008 at 7:33 AM
