HOME
ASK A QUESTION
REPAIR GUIDES
BECOME A MEMBER
LOG IN
Login with Facebook
OR
Remember me
NOT A MEMBER?
FORGOT PASSWORD?
CONTACT US
PRIVACY POLICY
TERMS AND CONDITIONS
Home
Ford
F-150
Engine
Oil Pump
1997 Ford F-150 oil pump
KASI1211
MEMBER
1997 FORD F-150
6 CYL
2WD
MANUAL
160,000 MILES
Where is the oil pump located? What could cause the problem to lock up?
Monday, March 15th, 2010 AT 4:14 PM
DOCFIXIT
MECHANIC
Pump is on bottom of engine inside oil pan
Monday, March 15th, 2010 AT 4:17 PM
KASI1211
MEMBER
1 POST
My engine is locked up, could the problem be the oil pump?
Monday, March 15th, 2010 AT 4:26 PM
DOCFIXIT
MECHANIC
Engine locked up you will need it rebuilt or replaced
Tuesday, March 16th, 2010 AT 12:40 PM
Please
login
or
register
to post a reply.
Related Oil Pump Content
1997 Ford F150 Oil Pump
Does My Windsor 4.6 Motor Have An Oil Pump? If I Keep The Speed At 50mph And Above It Runs Normal. If I Have To Run At A Slower Speed It...
Asked by
ardith ainslie
1 ANSWER
1997
FORD F-150
VIDEO
Oil Pump and Pan Replacement
Instructional repair video
1997 Ford F150 Erratic Oil Pressure Reading
My Truck After Running A Few Minutes Has An Erratic Oil Pressure Reading And Oil Pressure Light At Idle. Reving The Engine Slightly Causes...
Asked by
ksolomon
1 ANSWER
1997
FORD F-150
1997 Ford F150
I Have A 1997 F -150 Pickup And When I Put Oil In It It Does Not Show Up On My Dip Stick. I Took It To A Garage And The Guy Told Me That I...
Asked by
kerrbee
1997
FORD F-150
F150 2002 Oil Plug On Oil Pump Cover
I Have A 2002 F150 And I Removed The Plug On The Oil Pump Cover Right Next To The Oil Filter. I Lost About A 1/4 Of A Quart Of Oil. Do I...
Asked by
todd.howden
3 IMAGES
2002
FORD F-150
No Oil Pumping In The Right Side Of The Engine
No Oil Pumping In The Right Side Of The Engine. New Oil Pump. New Timing Chain Starts Fine But No Oil Pumping
Asked by
icepro
1999
FORD F-150
VIEW MORE
Engine Oil Change and Filter Mercedes
Oil Change and Filter Replacement Dodge Ram
