1997 Ford F-150 erratic oil pressure reading
KSOLOMON
  • 1997 FORD F-150
  • 6 CYL
  • 125,000 MILES
My truck after running a few minutes has an erratic oil pressure reading and oil pressure light at idle. Reving the engine slightly causes the light to go out and the oil pressure reading to retunr to normal. I think t is either a faulty electrical signal, oil pump, or clogged oil pickup in the oil pan. Suggestions?
Friday, September 12th, 2008 AT 8:52 AM
MERLIN2021
  • 17,250 POSTS
Remove the oil sender, and screw in a test gauge, take the readings, With warm engine 10psi is ok, and should go to 40-60 at 2000 rpm. If not the pump is weak, and or worn bearings.
Friday, September 12th, 2008 AT 1:37 PM
