No oil pumping in the right side of the engine
ICEPRO
  • 1999 FORD F-150
  • 5.4L
  • V8
  • 4WD
  • 350,000 MILES
No oil pumping in the right side of the engine. New oil pump. New timing chain
Starts fine but no oil pumping
Wednesday, September 23rd, 2015 AT 5:41 AM
HMAC300
  • 48,601 POSTS
You'll have to check for a blockage on the passage leading to head. There are two different engines on this vehicle.
Wednesday, September 23rd, 2015 AT 6:45 AM
ICEPRO
The engine is a 5.4 ford f150 engine
Thursday, November 12th, 2015 AT 4:32 AM
HMAC300
  • 48,601 POSTS
What vin is the truck there is vin L
Thursday, November 12th, 2015 AT 5:50 AM
ICEPRO
Yes vin L
Friday, November 13th, 2015 AT 4:33 PM
HMAC300
  • 48,601 POSTS
As I said it has to be a blockage if the cylinder heads were removed then you have the head gaskets on the wrong sides because they are NOT interchangeable. Recheck your work. Oil not going to one side from just replacing timing chain would still go to each head unless a blockage.
Saturday, November 14th, 2015 AT 7:10 AM
