1996 Ford F-150 engine
SOD MAN
  • 1996 FORD F-150
1996 Ford F150 6 cyl Two Wheel Drive Manual
after first start up. The next start up, the engine act's like it's starving for fule. With a slow idle and no responce to the throttle. After a short time I get responce to thottle, but still run's rough. Did full tune up a year ago, replaced fule filter again a month ago. Thinking fule position.
Monday, July 14th, 2008 AT 6:44 PM
BLACKOP555
  • 10,371 POSTS
How does the fuel system maintain its pressure after shut off/ it stay high or drops instantly?
Monday, July 14th, 2008 AT 9:53 PM
SOD MAN
I dont know how would I check.
Tuesday, July 15th, 2008 AT 7:16 PM
BLACKOP555
  • 10,371 POSTS
You will need to use a fuel pressure check guage and attatch it to your fuel rail on the schreader valve.
Tuesday, July 15th, 2008 AT 10:58 PM
