Bad oxygen sensors?
FORD MAN CHRIS
  • 9 POSTS
Fuel pressure has been verified, except for with the engine running because the engine won't start. I'm trying to find out what else could possibly make the engine not run. It seems as though the injectors aren't getting a pulse signal, and I need to know what to check for that.
Thursday, September 10th, 2020 AT 6:46 PM (Merged)
Hook up a noid lite at the injector/s harness connector it should be flashing if the circuit is good if it does-its coming from the injector/s
FORD MAN CHRIS
  • 9 POSTS
I'll try it, and let you know. Thanks
FORD MAN CHRIS
  • 9 POSTS
I put a noid light on the injector plug in, and both sides of the plug make the light come on but not flash, this was done with the engine being cranked, but not running.(Since it won't start).
The injectors ground drivers of the computer went south-it should be flashing if the ground drivers are good
FORD MAN CHRIS
  • 9 POSTS
So does that mean I need a new computer, or could it be a short somewhere in the wiring?
If you test the wiring and they all good replace the computer
FORD MAN CHRIS
  • 9 POSTS
Okay, I'll try that. Thank you.
FORD MAN CHRIS
  • 9 POSTS
Okay, I got the other problem fixed. Finally!
I got a new problem though, there is a really foul smell in my vent system, and around the truck, kinda smells like dead rat, it's really bad when I turn the dash blower on. No vibration in the fan, just a foul smell !
I would like to know what I need to do to get the culprit out before it gets really nasty. This smell is really bad. Please, help.
MACUSER
  • 1987 FORD F-150
  • V8
  • 230,000 MILES
Boggie when push on gas to go up hills
or when gun it to go faster.
Was told it might be oxygen sensor.
I have replaced everything else it could be.
So didn't know if it was a O2 sensor or oxygen sensor.
If it is by the first converter or what.
It has a new fuel pump and filer.
2CARPRO JACK
  • 11,533 POSTS
What exactly have you replaced? This could be many things, has it ever been on a scann er to se what is going on? Has the check engine light ever been on or is it on presently? At that mileage a fresh o2 sensor might be a good idea. That truck should only have one if it has 2 replace them both.
