1995 Ford F-150 severe loss of power
CLAYT
  • 1995 FORD F-150
  • V8
  • 144,000 MILES
Especially on any gradient it bogs down and I cant get past 80 on normal performance. It will slowly keep accelerating if I hit the pedal just right but at nowhere near the speed it should
Friday, June 18th, 2010 AT 10:52 PM
  • 109,885 POSTS
Has the check engine light come on? Have you checked to make sure the catalytic converter isn't plugged? Finally, have you checked fuel pump pressure?
Friday, June 18th, 2010 AT 11:21 PM
CLAYT
Havnt checked the cat but pressures good and no engine light
Friday, June 18th, 2010 AT 11:26 PM
  • 109,885 POSTS
Check to make sure the converter is clear, check for vacuum leaks, and I would also recommend checking the fuel pump pressure.
Let me know what you find.
Saturday, June 19th, 2010 AT 12:12 AM
