1995 F150 5.0 4x4 AOD 61k hard miles DTC 332
1995 FORD F-150
02TUNDRA
I'm having trouble with DTC 332 on my 1995 F150 5.0. When I purchased the truck it was plagued with 7 or more DTC's. I took the upper and lower manifolds off and had the local machine shop dip and clean both manifolds. I reassembled with brand new injectors, complete tune up and new egr valve and tube from lower to upper. I'm still down to just DTC 332. I then realized that the New EGR valve was not holding vaccuum so I purchased a junk yard EGR which does. Seems to idle better. I've replaced EVR solenoid as well. I've checked the vaccuum hoses with vaccuum pump and they seem to be fine. I keep reading about PFE/DPFE sensor as being a possible problem, yet I'm unable to locate it on my truck. I'm not sure if it has one. The diagram under my hood doesnt not indicate a PFE/DPFE in it. Do you know if it has one and where I might locate it ? I know my F150 has a crossover pipe in the rear from cylinder head to cylinder head. Is it possilbe that it's the problem, clogged ? or leaking ? I'm running out of Ideas..
Jun 16, 2007 at 11:17 PM
INDYUKE
  • 416 POSTS
That code for the PFE/DPFE tends to indicate that the EGR valve position sensor is complaining about something. It's the whitish "cap" on top of the EGR valve with wires going to it that tells the PCM how far the EGR is open.
In reality what that code is trying to tell you is that the PCM isn't seeing the EGR valve opening. I hope this helps.
Jun 17, 2007 at 10:38 AM
02TUNDRA
I'm not sure that it helps, I think your saying I may have an electrical open on the egr sensor to the pcm ?
Jun 17, 2007 at 10:47 PM
INDYUKE
  • 416 POSTS
Yes, either an electrical open, or the EGR sensor isn't reading correctly. Possible the EGR valve still isn't opening far enough or at all, though with everything you've done that doesn't seem like a high probability.
Jun 18, 2007 at 12:28 PM
MERLIN2021
  • 17,250 POSTS
P0332 Knock Sensor 2 Circuit Low Input
is this your code? check the knock sensor by knockin around it with a wrench!
Jun 19, 2007 at 11:10 AM
