1994 Ford F-150 Wont Start
FORDFLYER
  • 1994 FORD F-150
  • V8
  • 4WD
  • 148,000 MILES
My 94 F150 4x4 302 V8 wont start. Drove it home from work one night and the next morning nothing. Battery is about 6 mos old. My neighbor says it's either the starter or solenoid. All of the lights work until turning the key.
Any ideas?
Tuesday, June 17th, 2008 AT 1:57 PM
BLACKOP555
  • 10,371 POSTS
Does it click or anything?
Start in neutral? Do the lights dim when you try to crank it such as its getting voltage, if lights are bright suspect a faulty ignition switch or neutral safety switch.
If they dim check the starter and relay.
Tuesday, June 17th, 2008 AT 10:18 PM
FORDFLYER
I changed the solenoid and still wont start.
When you turn the key I can hear the fuel injector spraying fuel but the panel lights go out.
No clicking other than the fuel injector.
Wednesday, June 18th, 2008 AT 10:41 AM
