1994 Ford F-150 Will not restart until engine cools.
TIMHARRIS63
  • 1994 FORD F-150
  • 6 CYL
  • 100,000 MILES
Help. My mother in law has the 94 F-150 in question. It starts very well when the engine is cool. But after you drive it a few miles and turn it off, it will not restart until it has time to cool down. I'm trying to help as much as possible, but I'm not sure where to start. Any suggestions are appreciated.
Wednesday, November 25th, 2009 AT 3:11 PM
JDL
  • 16,098 POSTS
Welcome to the forum, when it refuses to start, have a helper crank it while you check for spark at the plugs. You can pull sprak plug boot, use known good plug in the boot, lay metal part of plug against metal part of engine to ground. Have helper crank while you watch for spark a the tip of plug. The autostore sells a spark tester. If you have spark everywhere, use a gage and check fuel pressure. My first thought was the tfi module, but, can't be sure.
Wednesday, November 25th, 2009 AT 3:32 PM
TIMHARRIS63
Thanks! At least that is a starting point.I was thinking fire or possibly loosing fuel pressure.
Wednesday, November 25th, 2009 AT 3:37 PM
JDL
  • 16,098 POSTS
I agree, you got to start somewhere, find out if your missing fuel or spark, to start.
Wednesday, November 25th, 2009 AT 4:00 PM
