1993 Ford F-150 Starting in cold or damp weather
JEDWELD
  • 1993 FORD F-150
  • V8
  • 4WD
  • 200,000 MILES
Truck wont start in cold or damp weather with out pluging it in even if temp is in the - 10 c what could be the promblem
Tuesday, December 18th, 2007 AT 2:02 PM
BLACKOP555
  • 10,371 POSTS
Check your distributor cap for cracks or carbon build up and moisture on a damp day.
For the cold start I belive you have a separate problem. A bad Coolant temp sensor or a dirty throttle body and plate can cause a hard cold start.
Tuesday, December 18th, 2007 AT 6:57 PM
