1993 Ford F-150 wont start
STINGER1472
  • 1993 FORD F-150
  • 6 CYL
  • 88,888 MILES
My 93 f150 wont start I put a ignition module coil wire set fuel pump fas filter on we did get it running one time when a mechanic replaced the ignition module with a better grade of one we also cleaned the ground for the module housing, does not get fire from the coil, any help would be apreacheated thank you
Wednesday, May 12th, 2010 AT 6:50 PM
Test the ignition coil primary and secondary winding resistances and the distributor pick-up resistance and for short to ground
Wednesday, May 12th, 2010 AT 7:22 PM
STINGER1472
Thank you for youre time. I have installed a new coil and will check the pick up for ground in the morning. Thanks again.
Wednesday, May 12th, 2010 AT 8:06 PM
