1993 Ford F-150 fuel pump
JIMMOLINE
  • 1993 FORD F-150
  • 6 CYL
  • 107,000 MILES
I have two gas tanks and the rear tank pump seems to be intermittent in working. When it does work, I can only use it if I switch to it at high speed as it will not work if there is any strain on the motor. How difficult is it to replace the fuel filter. Can I do it myself? Do I need any special tools. What should I expect to pay for a fuel filter? New? Rebuilt? Used?
Thanks,
Jim
Monday, June 21st, 2010 AT 4:08 PM
BLUELIGHTNIN6
  • 16,542 POSTS
Do you mean replacing the fuel pump, not filter?
Monday, June 21st, 2010 AT 4:11 PM
JIMMOLINE
Sorry, I meant replacing the pump. I assume it is not a filter problem as then it would affect both tanks. Correct?
Jim
Monday, June 21st, 2010 AT 4:18 PM
BLUELIGHTNIN6
  • 16,542 POSTS
Yes most likely. To replace the fuel pump you have to drop that fuel tank down. Then there is a lock ring on top of tank that has to be rotated counterclockwise to release the pump. No specialty tools are required and a new fuel pump costs around $150 for new
Monday, June 21st, 2010 AT 4:25 PM
