1991 Ford F150 V8 Two Wheel Drive Automatic
I have a problem with my 1991 Ford FI50, when I put the cables on the battery the starter turns over without the ignition being turned on to start, and when a set cables are used to boost the truck the engine starts though has an incredible high revving, and will not engage with a normal idle?
As well, when the truck runs normally it drains the battery sometimes in less than an hour and half, and the truck will not start?
SPONSORED LINKS
Saturday, May 31st, 2008 AT 2:10 PM
