1991 Ford F-150 Starter
THOR313
  • 1991 FORD F-150
Electrical problem
1991 Ford F150 V8 Two Wheel Drive Automatic
starter will not disangage after truck is turnned off. New starter new cylenoid and batt.
Sunday, January 10th, 2010 AT 7:18 PM
You sure the starter relay is not sticking or hook-up properly it will do that so as a bad ignition switch. Try banging on the relay when it continues to crank the engine over and see what happens-
Sunday, January 10th, 2010 AT 7:39 PM
