1991 Ford F-150 fuel pump
JECOMBS
  • 1991 FORD F-150
  • 6 CYL
  • MANUAL
  • 180,000 MILES
I cant get the fuel pump to come on for any one of the 2 tanks. The book tells me to replace the fuel pump relay I did. It also says to check the fuel pump fuse where is that and could it be the ECC relay. When I turn the key to run I can fell the ECC relay click? Why are the pumps not pumping?
Friday, February 20th, 2009 AT 3:51 PM
The fuel pump relay get its power from the 20ga. Blue fuse link on the starter relay, also test the inertia switch and the fuel pump ground circuit.
Friday, February 20th, 2009 AT 4:02 PM
JECOMBS
Where is the starter relay? The inertia switch is not triped it did trip it and reset it once. How do you check the fuel pump ground circuit?
Friday, February 20th, 2009 AT 4:22 PM
Starter relay -Follow the positive battery cable it'll lead you right into it, for the ground dunno the wire color could be black-you need an ohmmeter to check the wire to chassis ground, no continuity means its open
Friday, February 20th, 2009 AT 4:43 PM
JECOMBS
Got it it was the EEC relay. The only ting is that you have to put a fuel pump relay in it because they dont sell an EEC relay
Saturday, February 21st, 2009 AT 5:05 PM
