1990 Ford F150 4.9L F150 1990, Can freeze Plugs be replaced
1990 FORD F-150
NEHMO
Engine Cooling problem
1990 Ford F150 6 cyl Two Wheel Drive Automatic
I don't have a clear understanding of the history of this truck. The owner is offering it to me to use if I can fix it. I really need a vehicle now for work, so I'm trying my best to get it going.
After doing a number of repairs to the truck, and getting it going sort-of, I discovered two leaking freeze plugs, the front and the rear (on this inline 6). The leaks are too bad to ignore, and the rear one pours directly on the starter. (The truck is missing the radiator cap; this must be because the former user was adding water constantly and didn't want to pressurize the cooling system.)
The freeze plugs are very hard to access. I'm not even sure it's even possible to reach them with the engine still in the truck. So I'm wondering, is it possible to change those freeze plugs without removing the engine?
It makes a difference. I'm not really an auto mechanic, and I don't have a lot of tools. But I have a mechanical aptitude, and if it can be done, I can do it. But I need to know if it's reasonable to change them without removing the engine. I need to know how to proceed. Someone with experience with the engine would know.
I have to decide on a course of action. Has anybody changed those freeze plugs?
It's a 1990 F150 with a 4.9L fuel injected engine.
~~ Nehmo
Sep 13, 2010 at 4:48 AM
CJ MEDEVAC
  • 11,004 POSTS
See my profile..........Jeep Feller.........never messed with your truck!
Normally these puppies are installed with engine out, with no thought about you in the future. (I like CJs!)
Anyway, this may be an option....IF YOU CAN GET THE OLD ONES OUT....HALFWAY EZily!
If you go to Autozone or Advance Auto........You can obtain freeze plugs.......The kind you beat in and must have MEGA swinging room for your hammer!
B-----U-----T..........They also have the kind that are compression........You shove 'em in the hole, tighten with a wrench and WAH-LAH!!! You are done!
If you got the room to get them into the hole.
Your Thoughts?
If I done you some good, "FEEDBACK"---make me sound like a Saint!
REPLY?
The Medic
Sep 13, 2010 at 5:11 AM
