Want to change out the freeze plugs. What is the best way to do that.
51,233 MILES • 4.9L • V6 • 2WD • MANUAL
DPERDIVER
Freeze plug between engine and firewall is bad...would like to change them all out. Can I pull the engine and transmission together? Also, the pivot point for the gas and clutch pedals have worn the bushing to an enlarged hole...how do I repair this?
Thanks for your help.
Dec 29, 2014 at 3:56 AM
HMAC300
  • 48,601 POSTS
you can find the bushings maybe to fix the pedal or maybe anew or another one. for freeze plug you can pull both engine and trans if youwant then fix plug
Dec 29, 2014 at 4:06 AM
