1989 Ford F-150 Truck won't start
OBXFERNIE
  • 1989 FORD F-150
  • V8
  • 4WD
  • 15,000 MILES
My husband pulled into the driveway. The truck died and so did all of the dashboard accessories and the power windows. The headlights still work. Checked the fuses they all look good. The truck is getting no spark. I replaced the ignition switch. It will turn over but will not start. Any suggestions?
Saturday, November 8th, 2008 AT 10:15 PM
BMRFIXIT
  • 19,053 POSTS
No spark I would suspect the ignition module and replace
Saturday, November 8th, 2008 AT 10:28 PM
OBXFERNIE
I just went out and looked at it again. When I turn on the headlights I can see the dashboard gauges and they are still set like they are running. I can tell how much fuel is in the tank usually when you turn off the truck it goes down to empty. It is as if the truck just DIED! Could it still be the ignition module?
Saturday, November 8th, 2008 AT 11:08 PM
BMRFIXIT
  • 19,053 POSTS
Module effect and control the spark
no effect on gauges and fuel delivery
check for fuel and proper fuel pressure
Saturday, November 8th, 2008 AT 11:43 PM
