Removal of rear axles from track lock diff
TERRI LOBLEY
  • 1989 FORD F-150
Hi chasing info on the removal of rear axles from track lock diff we think it is an imported f150 if that helps
Sunday, September 13th, 2009 AT 9:58 PM
DOCFIXIT
  • 18,828 POSTS
Hi Should be semi-float 8.8 in. as in figure
https://www.2carpros.com/forum/automotive_pictures/198357_Graphic_129.jpg
Remove cover then diff pinoin shaft lock bolt.lower pinion shaft, push axle in C clip will be removed. Do both axles. CAREFULL not to rotate diff or spider gears will drop out.
Hope this helps
Thanks for donate
Monday, May 17th, 2021 AT 1:19 PM
