Login
Join
Ask a Question
Questions by Vehicle
Repair Topics
Testing / Diagnostics
Repair & Service Guides
Symptoms
Warning Lights
Trouble Codes
How It Works
Videos
Login
Become a Member
Home
Ford
F-150
Drivetrain
Differential
Axle
Replace/Remove
I am replacing the gear lube in my back axle with synthetic
2005 FORD F-150
70,000 MILES • V8 • 4WD • AUTOMATIC
TRLOUKS
MEMBER
1 POST
I am replacing the gear lube in my back axle with synthetic. How much lube do I need to buy to do it?
Jun 3, 2010 at 1:19 AM
Experienced Mechanic
It is based on the size of the differential. If it is a 8.8 or 9.75" it takes 5.50 PTS. If it is the 10.25" it takes 6.50 PTS.
Both use SAE75W - 140 Synthetic Rear Differential Oil.
May 17, 2021 at 6:20 AM
🔧 Tools & Auto Repair Parts
Shop on Amazon →
Add image or video
Ask a new question
Engine won't start
Engine stalls while driving
