1987 Ford F-150
JONATHAN HERRING
  • 1987 FORD F-150
Engine Mechanical problem
1987 Ford F150 V8 Four Wheel Drive Manual
my fuel pump relay keeps melting like it grounded somewhere but its not I check everywhere
Tuesday, March 3rd, 2009 AT 4:26 PM
BLACKOP555
  • 10,371 POSTS
Check the wires see if they are shorting out. How high amerage is the fuse? Check on the fuel pump inertia switch. Under the vehicle. If you ahve the dual tank model check to make s ure it isnt shorting out at the switch or at the second tank.
They have a tool that you can use to find a short.
Tuesday, March 3rd, 2009 AT 5:25 PM
JONATHAN HERRING
  • 5 POSTS
Thanks
Tuesday, March 3rd, 2009 AT 6:52 PM
