1985 Ford F150 Exhaust Manifolds
1985 FORD F-150
JKID5433
Engine Mechanical problem
1985 Ford F150 V8 Two Wheel Drive Automatic
I have a 1985 Ford F150, 302ci, Fuel Injected, 5.0L, 2WD. I need to replace a cracked exhaust manifold but the options for the replacement manifolds are either with or without exhaust control valve. I am not sure if I need one with and ECV or without one. Is this the same thing as an EGR valve?
Jul 30, 2010 at 5:45 AM
DOCFIXIT
  • 18,828 POSTS
ECV located where exhaust manifold hooks to pipe should be on right side and vacuum controled it deverts exhaust gas bak under intake to warm up and provide better fuel vaporazation during warm up. How about headers?
Jul 30, 2010 at 5:53 AM
JKID5433
My engine is completely stock and I wish to keep it that way. Headers I am told will not give to much of a performance upgrade if the engine is stock. The ECV option is for the drivers side manifold. I was told it was only needed for older trucks but no one seems to know if my year, my model needs to have that valve.
Jul 30, 2010 at 6:40 AM
DOCFIXIT
  • 18,828 POSTS
Yes it has one but it is a HCV on left side has vacuum line to it.
Jul 30, 2010 at 7:51 AM
