1978 Ford F150 6 cyl Two Wheel Drive Manual
tried everything, double checked the oil pump, installed correctly, filled filter with oil, when turning pump its goes to 15 to 20 lbs then the pressure disappears.
looked into filter empty, filled uo two, three times have oil pressure at first then disappears.
filter again empty, also filled pump up with oil.
how do I keep oil pressure when pre oiling it.
new engine
SPONSORED LINKS
Sunday, August 2nd, 2009 AT 7:51 PM
