2002 Ford F150 Changing oil filter
2002 FORD F-150
100,000 MILES • V8 • 4WD • AUTOMATIC
BABSH
Trying to change the oil filter and can't reach it. How are we expected to change it out. Any input. Thank you.
Aug 23, 2009 at 6:13 AM
JDL
  • 16,098 POSTS
Hello, I can't exactly see your problem? Maybe you need a rachet--extension-- oil filter adapter.
Aug 23, 2009 at 6:52 AM
MJR346
  • 132 POSTS
on 4x4, wheels straight forward, and buy a oil filter wrench made to go on a ratchet (most common oil filter wrenches won't work, I beleive including the ones that slip over the filter housing on it's top ) and you should be able to sneak it that way as this is the only way I've ever done it
Aug 24, 2009 at 8:11 AM
