1983 Ford F-100 Needs?
ABERACER
  • 1983 FORD F-100
1983 Ford F-100 Automatic 84950 miles
This has sat for ten years what should I check since it does not run?
Wednesday, August 4th, 2010 AT 5:37 PM
MOTORSAL
First- get yourself a chiltons or haynes manual. Then start by process of elimination. The problem(s) is either electrical or fuel. Try to eliniate one before going to the next. Check the plugs for spark. If good- check other electrical componets that have a direct link to fuel consumption, then go through fuel system if needed. Because it has set for so long you may want to get the carb cleaned out.
Saturday, August 7th, 2010 AT 1:11 PM
