1996 Ford Explorer P0171 P0174 Lean
PS make sure you clear the codes after each attempt to repair so you will know if you got it. It sounds like maybe your O2 sensors are bad. If they have failed, it will disturb the air fuel ratio and on the 5.0 if I'm not mistaken, it has a mid pipe with two banks, the left and right, which would be causing the computer to lean out the mixture.
Today I rented a code scanner and obtained the following codes from my Explorer. P0171 (System Too Lean (Bank 1)); P0174 (System Too Lean (Bank 2)); P0301 (Cylinder 1 Misfire Detected); P0401 (Exhaust Gas Recirculation Flow Insufficient Detected). I have read from this thread and my Haynes manual that P0171, P0174 and possibly P0401 may be attributed to a faulty MAF sensor, but I am not sure about the misfire in cylinder 1 (P0301) code. I also had a pending code (P0153(O2 Circuit Slow Response (Bank 2, Sensor 1)), but it disappeared after driving the vehicle for 28 miles and immediately scanning again while the engine was warm.
In the morning I'll swap the plugs and wires of cylinders 1 and 2 and see if the P0301 code changes to P0302. I did buy a bottle of Valvoline complete fuel system cleaner last week and added it to a full tank, but have only gone through a little more than half of the tank of gas. If a fuel injector is fouled, perhaps it may take longer to clean.
Any advice by an expert as to what is most likely the problem and what steps I should take to correct it would be appreciated, as my wife cannot drive our Explore until I can get it to pass emmisions testing and re-register it.
Thanks from Alaska!
Look around and listen for a vacuum leak. You can take a 3 foot piece of rubber hose...3/8 or bigger will work and hold one end in your ear.....move the other end around the vacuum lines and hoses...you will hear a vacuum leak pretty easily..
You can also spray carb cleaner around lines and gaskets....a change in idle indicates a leak where the cleaner is getting into plenum...
MAF can be cleaned....the explore should have the MAF that has the aluminum snorle tube and the actual MAF sensor has three anti tamper torx screws holding it in. I think they are t-15s....but they are the anit tamper ones..
You can get them out with a little work without the right torx bit..a small flat head screwdriver will work. I have also used a dremmel cut off tool to cut a slight slot in the heads of them so I can use a flat blade screw driver....when I have misplaced my anti tamper torxs and in a hurry...
Take it out and spray the two little wires with the resistor looking thingys (technical aren't I) with brake parts cleaner or Mass airflow intake cleaner...either will work fine..
You can use a q-tip on them too but BE CAREFUL....if you bend them too much or break the connection....you will most likely be buying a new one....unless you are real handy with a fine tip soldering iron....
Put it back together an clear codes and drive it.
Find those vacuum leaks too...
Suggested Repair
For lean codes on both banks, inspect shared vacuum leaks at the throttle body, major vacuum ports, and PCV line. If none are found, clean the MAF carefully or replace it with a Ford OEM sensor. Also verify the fuel filter and fuel pressure, clear codes after each repair, and treat oxygen sensors as a later check.
Conversation Summary
A 1996 Ford Explorer 5.0 with P0171 and P0174 was hard to start cold after vacuum hoses, the PCV valve, and MAF cleaning did not clear the codes. Advice ranged from injector cleaner, fuel filter, fuel-pressure testing, and oxygen sensors to a shared vacuum leak or faulty MAF. A later 1997 Explorer 4.0 with the same lean codes plus a misfire and EGR code drew similar advice: check common vacuum leaks, prefer an OEM MAF, and test the EGR passages and DPFE sensor.
