2000 Ford Explorer engine fault codes PO174 (check engine l
2000 FORD EXPLORER
138,500 MILES • 6 CYL • 2WD • AUTOMATIC
JAMETCALF
Bank 1 & bank 2 sensor engine running to lean
The car runs fine without any stuttering or power problems.
It starts and goes normal from a stop.
Is this an issue?
Should I disconnect the battery and reset the computer?
Nov 17, 2009 at 10:36 AM
RICKMAR
  • 170 POSTS
You have a very minor problem !!
* In the vast majority of cases, simply cleaning the Max Air Flow "MAF" sensor does the trick. I find it's best to take it off and spray it with electronics cleaner or brake cleaner.
MAF Sensor Location? Right near your air filter box on a large black air intake lead hose. It is a small black module with "Max Air" printed on it and a direction arrow (Air Flow).
* Make sure you are careful not to damage the MAF sensor, and make sure it's dry before reinstalling.
* Inspect all vacuum and PCV hoses, replace if necessary.
* Check for a dirty fuel filter and proper fuel pressure.
Remove your negative battery cable to clear code and re-set...wait 10 seconds...connect the battery cable. The CEL (Check Engine Light) will be out and you will be all set.
I "strongly" feel that cleaning the MAF Sensor will solve your problem with code P0174.
Good luck;
Rick
Nov 17, 2009 at 11:03 AM
