Ford Explorer P0174 Lean Code
PATRICKAHLA
Ford Explorer Sport 188,000 miles.4.0 engine.
I have a code PO174. System too lean(left cylinder bank)I have already replaced o2 sensors on both banks.So now I have no idea what to do.Could someone please help.
Jan 16, 2007 at 5:17 AM
2CARPRO JACK
  • 11,533 POSTS
If there are no vacuum leaks then its probably the Mass Airflow Meter. Ford ahd some problems with them.I would go to the dealer even if there is an aftermarket unit available
Jan 16, 2007 at 5:42 AM
Suggested Repair
If no vacuum leaks are found, test or replace the mass airflow meter. Ford had known issues with these sensors; a dealer unit is preferred over aftermarket.
Conversation Summary
A Ford Explorer Sport with a 4.0 engine and about 188,000 miles has code P0174, system too lean on the left bank, after both banks' oxygen sensors were replaced. The expert says to rule out vacuum leaks first; if none are present, the mass airflow meter is the likely cause and a dealer replacement is recommended.
