1996 Ford Explorer Belt Tensioner Release Fix
GAGS61
I'm in process of replacing the belt on a 96 explorer 5.0 V8. I am having trouble finding the release for the tensioner pulley. Referencing the following picture http://autorepair.about.com/library/illustrations/bl779lib.htm The diagram under the hood says the red is an idler as well as the bottom left. The tensioner pulley is directly above the idler on the bottom left. Am I close? How do I loosen the tensioner to install new belt.
THanks
Apr 5, 2006 at 4:10 AM
PEPPERMRJ
  • 1,158 POSTS
I'll take your word for it. :)
the tension is released in one of two ways. For those units equipped with a half inch square drive hole use a half inch drive breaker bar. For those units without use a suitable size socket on the breaker bar or a large long wrench on the tensioner idler pulley center bolt.
Apr 5, 2006 at 2:51 PM
Suggested Repair
Release belt tension with a 1/2-inch drive breaker bar in the tensioner's square drive hole if equipped. If there is no square hole, use a suitable socket on a breaker bar or a long wrench on the tensioner pulley center bolt.
Conversation Summary
The owner of a 1996 Ford Explorer 5.0 V8 could not find how to release the belt tensioner while replacing the serpentine belt and asked whether the pulley above the lower-left idler was the tensioner. The expert said tension is released either with a half-inch drive breaker bar in a square drive hole or, if none is present, with a socket and breaker bar or a long wrench on the tensioner pulley center bolt.
