1998 Ford Explorer Lean Idle Codes
KTWILLIAMS9
P0118 Engine Coolant Temperature Circuit High Input
P0171 System too Lean (Bank 1)
P0174 System too Lean (Bank 2)
P0430 Catalyst System Efficiency Below Threshold (Bank 2)
[b:ee8bbef9e1]98 Ford Explorer 4.0 2wd[/b:ee8bbef9e1]
I have read up on these problems my main concerns are the 171,174 codes. I have been told to try to clean the mass air flow sensor is this a good choice of options and how do i go about removing it safely and cleaning it. As for the other two codes any information on them as well would be appreciated. Main concern is the not starting, and idling really low which are symptoms of the 171,174 codes i have been told. Any advice would be great.
Nov 18, 2006 at 10:14 AM
CARUNDELL
  • 602 POSTS
[quote:ca1958bfec="ktwilliams9"]P0118 Engine Coolant Temperature Circuit High Input
[b:ca1958bfec]98 Ford Explorer 4.0 2wd[/b:ca1958bfec]
I have read up on these problems my main concerns are the 171,174 codes. I have been told to try to clean the mass air flow sensor is this a good choice of options and how do i go about removing it safely and cleaning it. As for the other two codes any information on them as well would be appreciated. Main concern is the not starting, and idling really low which are symptoms of the 171,174 codes i have been told. Any advice would be great.[/quote:ca1958bfec]
Hey kt,
2 most common problems ..... 171 and 174 codes caused by: MAF and failure of the lower and upper intake seals. If you have a scantool that displays data stream I can walk ya thru a quicky diagnosis for it. As to the MAF many will test within spec (on the low side though) and still be bad. Let me know!
Chris
p.s. I would also address that coolant temp code too as it could also be the cause of your troubles!
Dec 14, 2006 at 3:51 AM
BRYFINGALLS
[quote:52fbc5878f="ktwilliams9"]P0118 Engine Coolant Temperature Circuit High Input
[b:52fbc5878f]98 Ford Explorer 4.0 2wd[/b:52fbc5878f]
I have read up on these problems my main concerns are the 171,174 codes. I have been told to try to clean the mass air flow sensor is this a good choice of options and how do i go about removing it safely and cleaning it. As for the other two codes any information on them as well would be appreciated. Main concern is the not starting, and idling really low which are symptoms of the 171,174 codes i have been told. Any advice would be great.[/quote:52fbc5878f]
Jan 17, 2007 at 9:16 AM
Suggested Repair
For P0171 and P0174, check the MAF sensor and the upper and lower intake seals; a MAF can test low-normal and still be faulty. Also diagnose the P0118 coolant temperature circuit, since it can contribute to hard starting and low idle.
Conversation Summary
The owner of a 1998 Ford Explorer 4.0 reports P0118, P0171, P0174, and P0430, with hard starting and very low idle. An expert says the lean codes are commonly caused by a faulty MAF or failed upper and lower intake seals, and that the coolant temperature code should also be addressed because it can cause the same symptoms.
